dieseltruckdriv
Dec 02, 2022Explorer II
Boon Docker wrote:MFL wrote:
If opening a faucet doesn't work, and most everything has already had AF pumped through it, including the toilet, I'd just blow air through the city hookup, opening the outside shower first.
This will force AF, that is in the lines, through and out the outside shower. After that, blow all lines, faucets, and low point drains. You don't need to have AF sitting in the lines all Winter. Open the low points, blow AF out there too.
Jerry
X2
Me three. I don't let the pink sit in the lines all winter either, but it was the last thing in the lines if there is a fitting that sits low enough to gather water.
