Vintage465's avatar
Jul 16, 2020
TST, TPMS with internal sensors
I'm ready to stop taking chances with a blow out and get a TST pressure monitoring system for my trailer tires. Then I came across the internal sensor type set up. Anyone used one of these? Seems pretty legit and straight forward. No doubt if there was an issue with a sensor you'd have to take the tire off, run it to a tire shop, then have a look.............that does sound like a pain.........if something went wrong Thoughts?
https://tsttruck.com/507-series-4-internal-sensor-systemtst-507-int-4.html
  • JoeH wrote:
    I have to replace the batteries at least annually on my 12 sensors. Easy to do when they are external.
    A few years ago I bought a 10-sensor Tire Tracker TPMS. Not knocking Pressure Pro, I went with Tire Tracker because of the lifetime warranty. But I digress. As stated above, I change the batteries annually. I've not experience any inconvenience when adjusting the air pressure; I figure I'd have to remove the valve stem cap anyway. Good luck with your search. Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
