Almot
Dec 07, 2013Explorer III
The manufacturer only sent me a drawing with 1.1/8 studs thickness, 1.1/2 width, and their approximate location. I call them "studs" because this is the top part of the rafter, it is arched, and the bottom part of the rafter is flat (where interior ceiling panels are attached).
2.5" screws I chose based on the fact that total thickness of metal bracket foot + particle board + stud = 1.3/4". Also, the bracket foot is flat but the roof is arched upwards, so there were small gaps between the bracket foot and the roof. Though, these gaps under the bracket foot had disappeared when I tightened the screws in studs and flattened the particle board under the bracket. The screw go all the way through 1.1/4" stud, so I guess it doesn't matter whether they
are 1.3/4" or 2.5".
Yes, I pre-drilled 3/32" pilot holes all the way through the stud as recommended for "softwood", which is a particle board. For a "hardwood" it's recommended 7/64" pilot, but I don't know how "hard" is the stud. Could be just a regular pine board. The root of #10 tapping screw is 1/8", and in the woodworking blogs the opinion is not to drill any pilots when the root is less than 1/8".
Since the screw goes through the stud anyway, it doesn't matter how long it is. Photo - sorry, don't know how to resize it on Skydrive.
The bracket is 6" long, parallel to the back of the trailer. 3 screws in the stud and 2 just in particle board (those are 1/2" long).
are 1.3/4" or 2.5".
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
