dougrainer
Jan 29, 2014Nomad
I WORKED building both Trailers and Motorhomes. The FACTORY supplies all power tools. Only hand tools are purchased by the line worker. There would be no reason to use a battery operated Drill as it would take too long to drill holes and such. There is MORE than ample light in the RV's when building. The Electrical station is designed and they have various lighting to help do the work. This is the OP's take and if you follow the OP's threads, he has NOT found anything a OEM does that is satisfactory to him. He likes to bash RV techs and OEM's equally. Remember, this was NOT an actual line worker as can be proved. The worker just lives in the area. Yes, that is a good thing, IF you live in an area, then you are as dumb as others in your area. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
