- joebedfordNomad IIINever one to give up on a challenge, I discovered that there is a certain position of the latch and the tumbler that if you push down on the end tab of the tumbler with the key in, it will slip into place. The latch itself seem to be the same as a standard one except there is a hole for a pushrod from the remote solenoid. I'm pretty sure I can just ignore that.
I will get a new one to replace this Baker 359. Which ones have steel innards? - cavieExplorer
joebedford wrote:
I know they're not expensive for a standard handle. This one looks exactly like a standard handle but is also a remote lock (that I never trusted). I'll have to pull it out and see if a standard handle will fit.
Steel innards? Does that mean that some brands have plastic parts?
No. Pot-metal. Junk. - jmckelvyExplorerI had one do that several years ago. I replaced it instead of fooling around trying to fix it.
- drsteveExplorer
Prolly not plastic, but cheap cast "pot metal" parts are a definite possibility. - Itinerant1ExplorerIf it's the 4 little screws that loosen up inside which causes the cover plate not to hold parts in place just take a drop of loctite on the screws.
Use the blue grade... "Loctite Threadlocker Blue 242 is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces." - joebedfordNomad IIII know they're not expensive for a standard handle. This one looks exactly like a standard handle but is also a remote lock (that I never trusted). I'll have to pull it out and see if a standard handle will fit.
Steel innards? Does that mean that some brands have plastic parts? - drsteveExplorerUsually when they fall apart, it's due to something wearing out as opposed to just a screw that loosened up.
I'd replace it. - cavieExplorerJust change it out.Buy Buy with a steal innerds.
- JimK-NYExplorer IIFor $25 I would think you might just replace the whole lock mechanism. That is what I did when I have a part break so the lock would no longer open.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
