Damdifino
Sep 08, 2018Explorer
lostbytes wrote:ScottG wrote:
Exactly what mine did when the start cap died.
Yup. You not getting enough help from the capacitor. You'll need an soft start capacitor. It used to be you'll need an hard start capacitor but the newer soft are a little easier on the motor windings. Older ac usually needs some extra help because they wear out and need more wattage to get going. Just get one and hook it up piggy back to the original capacitor. Look up on YouTube/Google search about how to hook one up on an RV ac.
https://www.loveyourrv.com/installing-hard-start-capacitor-into-my-rv-air-conditioner/
Here's one on hard start.
If one of those original caps is bulging then it need to be replaced first. Then try ac. If problem not solved, then add soft start.
I have a MicroAir EasyStart installed. It's functioned perfectly for two months. Part of its "brain" includes a start capacitor. So far I've heard check the hard start capacitor, run capacitor, and fan motor. Fan turns easily, if that's any indication.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
