Memphisdoug
Apr 15, 2016Explorer
Turning Brake Drums
I want to get the surface that the magnets ride on turned on my brake drums. Is this something that a shop that turns brake rotors and non-trailer drums can do or do I need to look elsewhere?
Boon docker wrote:
He is not wanting to have to brake surface turned, he wants to turn magnet surface.
Gdetrailer wrote:Boon Docker wrote:
You can buy new drums for $40-$50 each c/w new bearings. I bet that it would cost about the same amount to turn them, if you could find a place that would do it.
No, it doesn't cost as much as new drums..
Last time I had a auto drum turned it cost about $10 per drum, that was at least 20 yrs ago.. Might expect $15-$20 per drum now days..
If the drums have enough meat in them and you are turning 4 drums at $20 per drum you will spend $80 vs $200 at $50 for new drums..
There is nothing wrong with having a drum turned provided it is not worn past the max inside diameter.
The only reason to replace is if it will require to much removal of material past the max diameter or the drum is too far out of round.
People now days have gotten rather lazy and are willing to pop for new drums..
Memphisdoug wrote:
I was speaking of the inside face of the drum where the actuating magnets make contact with the drum. Mine are currently not very smooth. I am replacing everything else (complete backing plate assembly) so I figured I should give the magnets the best chance of working by smoothing out the surface they ride on.
RoyB wrote:
The wheels are all the same just go to your local auto shop....
If they mount them for you just be sure they don't get over anxious with the wheel grease... Too much gets into the electric brakes and makes them non working pretty easy...
Roy Ken
