- beemerphile1Explorer
GordonThree wrote:
beemerphile1 wrote:
If you have a problem - fix the problem. A disconnect switch is very likely to create a much larger (even fatal) problem.
Suggestions on fixing constant false alarms would be helpful.
Install a new detector, didn't think that needed said.
If a new detector still alarms, it may be a crazy idea, but maybe the detector is doing what it is supposed to do and telling you that danger is present! - Buckeye_ChuckExplorer III did not start this post for the intention of debating the merits of having or not having a CO detector. I simply want a way to turn it off while I am using a bug bomb to fumigate the inside of my camper. The last time I did this my CO detector went off and was beeping for 4 hours straight while we were out of the camper. I do not want this to happen again out of respect for my neighbors.
- Dave_H_MExplorer III did the same as Gordon. If it is on all the time what good is it?
i had to whack the wires anyway to get the new one installed. :h - MEXICOWANDERERExplorerAn alternative?
Kidde
Kidde KN-COPP-3 Nighthawk Plug-In Carbon Monoxide Alarm with Battery Backup
4.5 out of 5 stars 2,247 customer reviews
| 166 answered questions
#1 Best Sellerin Carbon Monoxide Detectors
Price: $38.77
- BobboExplorer IIIIf replacing the detector doesn't fix the problem, the detector is not the problem.
See my earlier response re:finding the CO source in my MH. - mike-sExplorer II
beemerphile1 wrote:
No one with the problem has died yet!
If you have a problem - fix the problem. A disconnect switch is very likely to create a much larger (even fatal) problem. GordonThree wrote:
Start with a new detector. Try a different brand. Even get a battery powered home unit. Try a different location in the RV. If you still have issues, start digging into alarm trigger sensitivity levels as some are made for different levels.
I would not be without all three, smoke, propane and CO detectors.Buckeye Chuck wrote:
Entire unit? The whole RV?
Is there a way to disconnect or turn off the carbon monoxide detector without cutting the power to the entire unit?
What exactly is the issue you are trying to resolve.- GordonThreeExplorer
Suggestions on fixing constant false alarms would be helpful. - beemerphile1ExplorerIf you have a problem - fix the problem. A disconnect switch is very likely to create a much larger (even fatal) problem.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
