- firemedic1992ExplorerI did check using a voltmeter and no power was getting to the head. Once I disconnected the coax from the wall amplifier and used the new in-line amplifier supplied with the new antenna, it worked.
- Did you make sure power was getting to the head?
- firemedic1992ExplorerThat's the antenna I have, the King Jack HD.
Thanks! - Yes, the Sensar would be a good replacement, however you should get the wingman to go along with it.
You may want to consider the Jack antenna.
Jack antenna
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
