X2 - yup, RFI caused by the LEDs
My fix was to change to the cheap $4.99 EBAY/CHINA boards. You can get ten for less than $50. In my case it didn't matter which LED light you would turn on in the trailer - they all bothered my HDTV receptions as well as my NOAH WX radio and cut back on received two meter/440 Ham radio reception. It did not bother my AM/FM JENSEN radio...
The RFI Problem comes from the BUCK BOAST Regulator chips on your new LEDs lights...
You can see the regulator chips just under the red wire here in this photo
The cheap ebay/china boards only have LED lamps installed on them - no regulator components.
If you are using a contained replacement bulb type the regulator chips are inside the assembly.
Since I already had a bunch of the regulator type LED SMD boards I installed a three position switch in my existing ceiling lamp fixture where it selected OFF-ONE-BOTH. Making the ONE position the cheap $4.99 ebay/china LED board. This way I could cut my lights in half power while we were camping off the power grid using the OTA Batwing antenna for the Natl Broadcast signals from the local towns. The signal strength of the camp ground CABLE connections over ride the RFI being received. However my NOAH WX radio signal still gets interfered with whether I am camping off the power grid or at a camp ground.
Some have used this type of ceiling lamp fixture that comes with a ON-FF switch for each side. Then have one side using the just the cheap $4.99 led EBAY/CHINA SMD board.
This is a well documented problem and after many discussions with the different LED manf they mostly say the problem is not big enough for them to make big changes in how the make the LEDs.
The other problem is the manf are within the FCC limit rules for creating RFI that may interfere with your other electronics. Only one company being STARLIGHTS Inc Jason Weaver is about the only one that will talk about the problem.. He was playing with a different regulator called PWN regulators with an EMI Bridge. I never heard anymore about this...
The downside for using the non-regulated type SMD boards is the voltage range we play with. My setup uses 12.0VDC to 14.4VDC VOLTAGE range and some claim this may shorten the life of some non-regulated LEDs. So far after a couple years of use I have only lost one three segment line of LED lamps on one board. I figure I can wait a lot longer and still get more life of the LED board and then just replace the whole thing. $4.99 is not too much of cost factor to worry about it.
A few HAM types have played with installing capacitors and wire beads at certain places around the boards and fixtures etc and may have some success in killing the RFI. The 1/8-inch square chip capacitors are too small for me to work with hehe...
Just my thoughts
Roy Ken
