When I first bought my 2015 Solaire 220X I was able to receive several channels on my TV. Now-a-days I am lucky to be able to pull in 1 or 2 channels. The antenna is stationary (not crank-up). I kno...
Check the coax connections for problems. Check for voltage problems at the antenna. Run a temp coax from the antenna to the booster and the booster to the TV. Also research and gather information on your model including trouble shooting.
Compare current reception to a neighbor especially one with the same antenna. Do you rescan channels when you move CGs?
