BFL13
Mar 15, 2021Explorer II
Hurricaner wrote:
The msw inverters will generally be more efficient on some loads as there is just a lot less components. To get an apple to apple comparison both inverters should be of the same type. I would also rerun the test with a 100 watt light bulb. Tvs can draw different currents depending on the picture being displayed.
Sam
Yes, TV draw depends on the picture brightness selected--the brighter the higher the draw. In the OP test, the TV stayed the same.
If the MSW would be more efficient, that just makes the PSW 2000w inverter in the OP look better I think.
I do have a 3000w MSW in the attic somewhere I could try. It has a display panel though, showing watts draw and battery volts, so that would add a little to the "on" draw I suppose. Might get at that later
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
