Davidlee64's avatar
Davidlee64
TV Problem?
I have 2 digital LED TV sets. One in the bedroom, and one in the kitchen/living room. I have a Lava HD-2805 antenna, connected to a Winegard RV-7042 wall plate. Reception is very acceptable as is. The problem I have is the kitchen TV has tiling and sound issues on one channel (#7) only. The bedroom TV receives the same channel (#7) with no problem. I have swapped coax cable connections, and no matter how I connect, the kitchen TV refuses to receive (#7) without tiling. The TV works fine on CATV where it is tuned via the cable box (TV channel #4), but I don't have CATV in my RV. I purchased the TV 3/22/13 so it is out of warranty. I think my option is a new TV set in the kitchen? I watch the channel (#7) quite frequently.
  • X2 on sch911's suggestion to look for electro magnetic interference. Start Turning other things, especially lights, off to see if it has any impact on the tv
  • Is there any other electronic device that could be interfering with the kitchen TV through EMI? A WiFi router, cordless phone, etc...?
  • Swap TVS....bedroom to kitchen, kitchen to bedroom
    As mentioned..TV Tuners are different UNLESS TVs are the exact same models....not Brands but Models
    Have 2 Vizios in 5th wheel.....one gets a couple more channels then other one
    Quality/abilities of the tuners.
    Same with the 2 TV in house....same OTA antenna. Same brands/different models
  • Not all televisions recieve the same. I have no cable or sat at my home, over the air only, My antenna booster has two outputs which one goes to a Vizio LCD and the other goes to an RCA plasma. no matter where I put each unit or which cable I use, I get 3 extra channels with the Vizio, and there is one channel set (7.1-7.3) that occasionally pixilates on the plasma but not on the LCD.
    Some units are just a little better at picking up weaker stations.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
