- MrWizardModeratorUnless bolt tv mount
Should be standard bracket on back of tv
Look down inside - pitch_blackExplorerYea looks similar, can't get behind unit, thanks
- MrWizardModeratorInfo is scarce and no pictures so I'm only guessing
But it sounds like it is mounted on gas lifts
And the push button, is for a latch release, kinda lie the push button for the trunk on some cars
The latch broke, or the switch wiring is shorted and staying unlocked
These are usually momentary duty, so if the switch stuck the unlock solenoid will burn out then not open
It does sound like the spring behind the latch or the latch lever has broken
You will have to get inside the cabinet to check this out - DutchmenSportExplorerNot sure if yours is the same, but maybe this will help:
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
