Sep 20, 2013Explorer
SCClockDr wrote:
Hi All
I made a few mods to our Refer to improve its cooling function.
- Replaced failed external fan thermistor with an attic fan thermostat from Lowes
- Replaced the OEM external fans with Magma 12CM Fan Magma Component Twister Bearing Detach Blade
- Added R-Max Iso board insulation to the rear of the refer and the inside of the slide wall.
- Installed a 100K pot from Radio Shack in series with the chill box internal thermistor to fool the control board's temp sensing
A couple of sample images.
Looks great. But could you tell us how this improved the efficiency?
Thanks,Sam
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
