SCClockDr
Sep 21, 2013Explorer
Sure Sam
Previous to the mods our unit had difficulty when temps were above 90°F, a 5 setting was not keeping it out of the 46-54°F range. now the unit hovers in the low-mid 30's on 2 or 3 depending on outside conditions. (Hi 90 - 100's I set it on 3) The efficiency is greatly improved IMHO, YMMV.
One side effect is the Digital readout on the fridge is now erroneous, now reads 38-40 vs 33-35 & not linear in its error. We use an inside/outside remote thermometer to keep track of actual temps.
When the pot failed (went from 100K? > 5K?) the symptom was a freezing chill box as the heater never shut off. Switching the mod off is safer than turning off the fridge @ night.
We have setup in a mid Texas church tarmac lot this summer for 3 weeks @ 90 - 103° temps and not a problem.
Pics to follow.
- The attic fan thermostat replaced a non-working fixed temp thermistor. This allowed to adjust the fan on, set point so the fans come on sooner & run longer, improving heat transfer.
- The Twister fans replaced a pair of OEM sleeve bearing fans. One OEM had seized & the other was getting louder. The Twisters have magnetic bearings so the fan floats on a magnetic field. This reduced noise, current draw, & increased reliability I hope. (3 years and still church mouse quiet)
- The ISO board (R-Max 1/2") was added mainly to block solar gain. I did this to both keep more of the cold in the freezer & upper chill box & as a buffer to the slide wall heat gain when the sun is beating on that side of the trailer. The amount of improvement was not discreetly monitored, I believed it did help a bit.
- The internal chill box thermistor mod of adding resistance in parallel initially consisted of a 100K? pot. I have since added a 33K? fixed resistor in series with the pot to get the full range use of it and added a switch to return to stock if the pot fails or to test. (The original Radio Shack pot failed after 2 years) This mod makes the controller believe the chill box is warmer than reality, causing it to keep the heater on longer thus driving down the inside temp 2-8°F.
Pics to follow.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
