campsmoke's avatar
campsmoke
twin fans mounted behind the fridge
Well we tried putting a work light {caged of course} behind the fridge to see if that would stop it from shutting down! No dice - still shuts down even at 48F! When I took the upper vent panel off on the side of our coach I found that there are twin fans mounted in there! Well I have not noticed them running ever! I must check the fuses for those fans and hopefully get them going again - it may be the answer to the fridge shutting down when the temp drops between 40 and 50 degrees F. Will let you know. If anyone else has twin fans there please advise. I cannot even find an instalation manual for them.
  • if you bought the rv used? somebody added them so the frig cools better, as for your frig temp , you need help. and some one on here will chime in.
