TempleinCanada
Dec 02, 2020Explorer
Two Battery Bank Question
I recently installed a 2nd battery bank that is connected through a transfer switch that switches between shore power and Inverter Power. This new addition has a battery charger that is powered through the transfer switch when shore power is connected.
I have left the OEM bank connected to the OEM 12 Volt side with OEM converter which charges the 12 Volt side of my trailer. I have both the OEM Converter and the after market Battery Charger powered through my transfer switch.
I also have 500 watts of solar on the roof with a 30 amp solar controller that can charge 2 battery banks (fully charges the OEM side and then switches to new side when OEM side is fully charged)
This works great as both sides charge with solar when I am not connected to shore power and when I am connected each battery charger charges their respective battery bank.
So both systems are isolated from each other except when the Solar is charging.
Here is my question: If one of my battery banks becomes low in available amp hours could I connect the 2 battery banks together (with a manual switch)to equalize them (I know it is not ideal, but would be for an emergency only)
My main concern is that the solar controller sees the 2 battery banks as separate, what will happen when it sees both of them together????
Here are the specs of my components
170 Watt Carmanah Solar Panel GP-PV-170M
340 Watt BougeRv Solar Panel DSM-170W + DSM-170W
30 Amp Go Power Solar Controller GP-PWM-30-UL
1500 Watt Samlex Inverter PST-1500-12 Pure Sine Inverter
15 Amp Samlex Automatic Charger SEC-1215UL Battery Charger
30 Amp Samlex Transfer Switch STS-30 Transfer Switch
30 Amp Samlex Inverter Remote Control RC-300
