Our 320RLDS TT's main or large entry door has sagged enough that the slide lock bumps into the hardware below the cutout it should fit into. While I could enlarge the length of that receiving hole, I...
Is it the hinge or the door itself? If the hinge isn't pulling out at the top and there is no adjustment I'd look at the door. If you measure the 2 diagonals of the door they should be the same, if not it's out of square and that's the problem.
Measure the door opening the same way to make sure it isn't racking.
