Our 320RLDS TT's main or large entry door has sagged enough that the slide lock bumps into the hardware below the cutout it should fit into. While I could enlarge the length of that receiving hole, I...
Doxiemom has the common fix. Some will use E clips instead of wire. The biggest cause for this is using the door to pull yourself up the steps. I suggest you get the folding door handle and use it.
