Rmack1
Jan 14, 2014Explorer
wa8yxm wrote:
I may be the one who suggested dropping the parallel cable.. I do not believe that is necessary but it might give the O/P some "Piece of mind" in the other thead.
Fact: If you have two generators parallelled,, What are the odds of you starting both of them at PRECISELY the same time? (I'd say the word "Impossible" applies here). so clearly one of them is running wile the other is sitting there, and no damage happens.
If you run them long enough, what is the odds that one will run out of gas before the other.... Like about 100%, and once again one will be running while the other sits there.
So I would not believe it will cause a problem.. I believe Honda and the other companies that allow paralleling have designed to prevent damage.
That's what I would think, too.
I actually called Yamaha, and finally spoke to a someone. I don't think they were specifically a tech, because I kept getting a line that sounded like legalese:
'The parallel cables are designed to work with two generators running.'
When I said 'OK, but CAN it work with just one generator running?'
'It will not function as designed. It is designed to work with two generators running.'
'What do you mean, it won't function as designed? I know that it won't put out enough power to run the air conditioner, but will it still put out current safely, to run other AC functions and appliances in my trailer?'
'It will not operate as it was designed to do. It was designed to operate with two generators running.'
We went back and forth a few times, I finally cornered this character into admitting he really didn't know what would happen. I suspect his whole purpose was to protect the company from legal liabilities, and didn't know squat about the practical engineering of the set-up.
So, I called a guy down at my local RV center, who had no legal vulnerabilities, and he said pretty much what you said; no reason why it wouldn't work, and in normal operation, one generator could go off line without warning, so it needed to be able to function with just one running.
So, I'm probably going to pull the two banana plugs on the down generator, and leave them in on the running one, just for a surplus of caution, and run off the parallel cable's 30 amp receptacle.
I don't think leaving the ground attached would hurt anything. This was the biggest hastle, as it took a tool and some dexterity to attach this each time.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
