CA_Traveler
Oct 31, 2022Explorer III
Cptn: 50A 120/240V service is SINGLE PHASE POWER the same as the typical house. Granted many think it's 2 phase, it is not and cannot be because it's a single secondary winding on the transformer and the center tap is the neutral. And yes it's 240V across the 2 hots.
You can install a load sharing inverter on each hot line with battery input. The 120V output of each (or at least one) will need to be connected directly to a A/C and not through the main CB panel.
Running one A/C on a 20A circuit can be iffy especially in a CG as the voltage will often be low. 1600W solar will yield about 1000W on a normal day unless you have tracking solar. So you can get some limited A/C run time when there is sun, no other significant loads and not so much when the sun doesn't shine.
You have more solar than most but is it practical for A/Cs? Probably best to use a gen for the A/Cs unless you have 30 or 50A shore power. All of this gets moderated depending upon the weather so roll the dice for any particular day and night.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
