Cptnvideo
Oct 31, 2022Nomad
Just got a call back from a GoPower engineer. Yes, I can do exactly what I want to do.
Example: I'm on 15 amp shore power. I want to run 2 ACs for an hour. I limit the shore to 7 amps for each line and the ACs are on separate lines. AC draw is 10 amps per line. The inverters supply the remaining 3 amps each or 60 amps out of the batteries.
Side note. If I had bought a smaller RV with 30 amp service, none of this would be an issue.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
