CA_Traveler
Nov 01, 2022Explorer III
Cptnvideo wrote:OK I didn't even consider that you would connect both inverters to one hot considering that you wanted to monitor each hot line with the inverter display.
Good points, wa8. I'm thinking about replacing the 3000 watt inverter/charger with 2 2000 watt units. Then using L1 of each so that I have monitoring and load sharing of both L1 and L2.
