time2roll
Nov 16, 2022Nomad
Get a battery charger that will pull 80% of the available power to charge the battery.
The other issue is voltage drop and the power support inverters do not give voltage support. If the voltage sags in the park it could put you out of business.
Check the specs but most chargers will work down to 90 volts.
