dougrainer
Sep 28, 2020Nomad
Calpantera wrote:
I am only working on the forward one so far and it does not move at all, I jacked up the rig a few inches with my floor jack and used a big prybar and block of wood as a lever and nothing. I put a wood block under the jack and lowered the rig and it just sits on the block. Going to leave it like that for awhile. Any other things I can do? I assume cracking the lines at the jack will do nothing. I see what looks like a plug on the side. If I crack that will that help?
Thanks again for all the help!
Are you POSITIVE the T handles are OPEN all the way? If open, then take a 5/8 wrench and gently crack open the Hydraulic line just a little. That will allow the bad jacks to retract. Have a catch pan under each bad jack. About 1 pint of fluid will come out. usually less. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
