BFL13's avatar
BFL13
Explorer II
Mar 13, 2018
Two Monitors on One Shunt?
In another thread the set up is where two monitors share a ?? 500a shunt. Each monitor specifies 500a anyway.
On the side of a shunt you get the little screw terminals (I have only seen the Trimetric 500a one) for the wires that go to the monitor. These read tiny amounts of ? voltage across the shunt to provide the readouts. Whatever. So, I am wondering----
If you have two sets of these wires on the shunt's little side screws going to two monitors, will that mess up their readings by not having the right tiny amounts, because they are in parallel?
It seems the two shunts agree on their readings, but that still leaves the possibility they are both equally wrong?
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 19, 2025
