Fortkentdad's avatar
Fortkentdad
Two Similar 12V battery in parallel and other questions
Well I just bought a second battery for my RV. My other battery is only a couple of months old so both are new this year. The one battery didn't make it through an unplugged camping weekend so we decided another was needed.
I'm not sure if I should hook them together as one bank in parallel or just swap the connecting cables when one is less than 1/4 full on the battery meter in the trailer.
We are only weekenders - and maybe a week or two here and there. Not full timers at all. And when we camp we are not running a lot of power.
One of my concerns is the batteries are not identical.
One is Canadian Energy's P27 MHC (CDN Energey P27 MHC) The other is an Everstart from Walmart it is the 27DC-850N apparently by Johnson Controls (CDN made)
Both are 27 "RV MARINE DEEP CYCLE" batteries. Both cost about the same ($111 & $119)
But not all the ratings are not exactly the same. The Everstart's MCA is 850 on and only 750 on the "Canadian Energy" battery
The Cold Crank on the Everystart is 675 vs only 600 on the CDN Energy battery.
Both have a "RC" of 180.
The Everystart lists its AMP/H as 120 the CDN Energy does not list AMP/H on the battery or website
As my converter is caput and I have not got around to replacing it I run off of my batteries all the time. I was using a old 6 amp trickle charger to charge up the battery but just bought a Genius Mini 2 charger. It is a waterproof unit and a "smart charger" indeed their marketing gimmick is "wicked smart". Each battery is connected to one of the wires from this charger 100% of the time. It is intended to be mounted on the RV (or boat or whatever) and left on all the time. It does say it is for RV's. The Mini-2 is really 2 4 amp chargers combined in one unit designed to keep two batteries charged. Genius GEN Mini2
I've emailed the manufacture for clarification on whether I should keep both batteries hooked directly to the the charger when they are hooked up in parallel. Or when I connect the two batteries does that make it like one big battery? I am concerned as the GENmini which I bought is intended for a battery with a max capacity of 120 amp/hr. If I hooked the two together are they then considered one battery with 200-ish amp/hrs?
I also have two Coleman 40W Solar systems - each has its own 7 amp charge controller. I will also be hooking these up to the batteries. I can hook them up together (parallel) to have 80w running through one of the controllers or keep them separate and charge each battery independently. Not sure which is the best approach.
SO - connect them in parallel OR keep them separate and just manual swap the connections when the battery charge is getting low. (I suppose there is some sort of switch that could be installed to make this easier).
Besides the inconvenience of switching the cables is there a downside to not hooking them up as one parallel bank? IF isolated that would ensure that we are never totally out of power. (been there done that didn't like hand cranking the slides).
I also wonder about the need to replace our converter. It's $300 for the WFCO OEM 55amp replacement $400 if I upgrade to Progressive Dynamic's unit. (CDN prices) What do I gain? Besides not using the batteries when I have shore power. If I keep them charged what is the difference?
David
  • I got 2 group 27s Trolling motor batteries from a battery dealer here for $170. They are Crown batteries
  • Bumpyroad wrote:
    so you bought a 120 AH battery size 27 at walmart for $119.00 canadian?
    think I'll head down to my local store on Monday.
    bumpy
    Actually the Walmart one was $111 - the other one was $119
  • To answer some of the questions,.....hook them in parallel,.....less chance you will run them down beyond the 50% rule.
    If you use more power than 50%, charge them,...one way or another, even if connecting jumper cables from TV.
    Then, replace the converter, one way or the other. A PD9245 can be had for around $129 off ebay. and it usually includes the remote pendant to control the charging stages.
    And last of all, a 1000 watt generator to power the PD,.......or a couple hundred watts of solar to give the batteries a fighting chance of living a longer life.
  • so you bought a 120 AH battery size 27 at walmart for $119.00 canadian?
    bumpy
  • This is what is balanced and best for twin twelve volt batteries.
    As it often doesn't cost a dime more to do this, I think it is worth the trouble.
    If you wish to understand the "why" surf here:
    correctly interconnecting multiple twelve volt batteries
    Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
