Thanks for all the suggestions and guiding questions guys.  I went out this afternoon since the sun came out and looked things over.
It's a Dometic Designer Series RM2804.  Separate doors for fridge and freezer.  Manual selection for Gas or Electric.  Separate temp knobs for either system.  And it's electronic ignition, which is nice.  The furnace is EI, but the stove is not, so I had no idea until I pulled the exterior cover off.  Took the cover off the control panel at the bottom to get a look around.  Just rods going through to the control in the back.  So I flipped the switch to gas and followed the instructions.  Sure enough, the light on the bottom started flashing.  Push and hold the starting button, light stays out.  But I can't hear anything.  So I go back outside and listen.  Nope, nothing.  Pull the cover off the bottom of the chimney and she's burning smooth.  I of course had to stick my finger in between the nozzle and tube to smother the gas.  That little ignitor will wake you right up lol.  And it lit right back up as quickly as I pulled my finger out.  Blew the flame out, the ignitor starts clicking and it came right back to life.
Couple of questions still:
Is the flame on/off, like a typical thermostat? Or does it adjust flow rate based on demand?
I need to vacuum out the dead flies and such from the back.  And there was probably a teaspoon of rust dust under the small tube in the stack.  Do I need to do anything else?  I've heard the vent covers on the roof can be brittle.  If everything is working fine, do I leave well enough alone? Or should I try to do a visual inspection of the flue.
The vent holes in the access panel/vent are huge.  There was a piece of nylon screen floating around in there.  I'm thinking aluminum would be a better choice, and stay formed to the curves better.
The gas is running now, plan to leave it on all night.  She is grabbing a couple thermometers at WW tonight so I can be a little more scientific than "pretty cold" or "wicked cold".
Also going to do some failure testing tomorrow.  Disconnect the ignitor and see if the light flashes when she call for gas.
The big question - Can I run the gas while towing the camper?
