Crushedstang50
Jan 11, 2020Explorer
Yes my plan was to just disconnect the stock coverter/charger. Then run the 120v wire from the shore power plug up to the inverter/charger in the front compartment so it was close to the battery bank. Then run the output 120v back to the breaker panel. If that would work how big of 120v cable do you think would be safe? To and from the inverter/charger.
