theoldwizard1
Jan 12, 2020Explorer II
BFL13 wrote:
I posted this yesterday, but people must have missed it. The pdf manual is linked in this, scroll down. Do what it says.
https://ultimatepower.com/products/inverter-chargers/pcul-series/3000w-pure-sine-inverter-charger-pcul/
It does have an automatic transfer switch built in. You are better off REMOVING the old converter and hooking your 12VDC fuse panel directly to the battery bank.
From the manual
While in the Standby (charging) Mode, the AC input is continually monitored. Whenever AC power falls below the Trip voltage, the inverter automatically transfers back to the Invert Mode with minimum interruption to your appliances - as long as the inverter is turned on. The transfer from Standby mode to Inverter mode occurs in approximately 10 milliseconds. And it is the same time from Inverter mode to Standby mode.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
