CharlesinGA
Dec 18, 2020Explorer
The plastic halo rings are largely to allow the bluetooth signal to "escape", but also allows more height for the older sensors.
If you have 30 lb tanks or are contemplating buying them to replace 20 lb tanks then you might consider spending the extra $20 or so a tank and getting ones with gauges built into them. These are float operated gauges so they should be fairly reliable, but of course require that you check the gauge on the tank.
Charles
Charles
