time2roll
Nov 13, 2018Nomad
Are you mostly concerned that the converter fan is running? That would be very normal running tank heaters.
Or are you concerned that the heat pads are not cycling off? With the outside of the tank in the 40s I would expect the heaters to be on.
Possibly check the amp draw to each pad with your clamp-on DC ammeter. I don't think larger wire is going to help unless you need more heat and this will only draw more power.
You really need utility power, run a generator 24/7, or plan to let the tanks freeze when camped in these conditions.
Raywatt wrote:While in use the tank heaters can stay off until you get below 30° F.
5. Tank Temperatures front to back taken with Infrared Thermometer when outside temperature is 38* to 44*
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
