MEXICOWANDERER
May 30, 2013Explorer
NYET )
Voltmeter. At the isolator (the type with fins and three studs)
Start engine BE CAREFUL. Select VOLTS
Touch Positive test lead to CENTER stud on isolator
Touch NEGATIVE test lead to EACH outer studs. Scrape through corrosion
Do you read voltage higher than 1.1 volts on ANY of the two studs check?
If YES the isolator is BAD. Scrap it.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
