Vintage465's avatar
Jan 01, 2016
Under trailer storage tubes
So in my smaller trailer, 2015 Creek Side 20fq, I am struggling to get everything situated. I didn't have a good place for my lawn (astro-turf) so I decided to go the rout of putting a 6" conduit across the trailer that has the "kit" installed with cap on the end and a latchable-lockable door on the access end. Then I got the bright idea to put the collapse-able chairs in an 8" version. So I have everything set up and started looking at how low that dude hangs. It's not as low as the axles, but hmmmmmmm. My trailer is pretty high with the offroad type chassis and I am sure just buzzing down the highway everything would be fine. Occasionally we take a jaunt off the pavement aways, but we never really go off-roading like real tight twisty ups and downs.
Wondering if anyone has strapped something like this under their rig and what your luck has been...........
Thanks,
  • I put one acrossed my tongue up against the camper that I use for holding the weight distribution bars and sway control bar.
  • corvettekent wrote:
    If they are close to the axle you should be fine. Maybe you could put one above the rear bumper.
    Thanks for the info. That would be quite the job to get it above the rear bumper as I already used that bit of real estate for a couple tool boxes and the spare tire.
  • If they are close to the axle you should be fine. Maybe you could put one above the rear bumper.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
