Red man wrote:
I am probably just gonna go with 2 awg maybe 3 and I need to know what size wire for neutral and size to use for ground was thinking 8 white and 10 green. gonna get 25 10 ft 1 inch pvc conduit 1 30 amp breaker and 30 amp 125 volt receptacle I had a electrician come out here I said I was gonna be doing the trenching and getting material he said 2100$ to hook it up/labor, figured I'd just do it myself I got a mini excavator to do the trenching, want to know that I am getting the right material and not missing anything.
wow, if you're doing all the work, it should be about an hour or two at most of labor and a permit fee. so I could see 200 to 300 bucks max if all he is doing is hooking in the two ends. now if he has to install a sub panel because yours is full and some stuff like that, then I could see the 2000.00
