wapiticountry wrote:
past wthose points it was on my dime to contract with a locate service to mark any underground lines since those are technically my responsibility.
Understood. My question remains.
It may be as simple as saying their definition of public right of ways and yours differ. The utility providers have easements to allow access to their lines that cross your property. This not only includes the lines to your meters but any other line that may transit your property. Transmission lines often do not follow roads and often bisect private property. It’s possible In utility company jargon an easement may be referred to as public access.
The fact that transmission lines may cross your property is a good reason to call for location services before trenching even if your personal utilities are far from the excavation site.
True, but any critical franchise utilities crossing private land are required to be permanently marked. Although those markers also get destroyed and the responsibility for locates is the same.
There is also a virtually zero chance that something like a high pressure gas main or underground power or fiber transmission is crossing his residential lot.
And there’s virtually no danger of hitting a water or sewer main unless digging far deeper than needed to put in a little power wire.
But dumber things have happened.
