wapiticountry wrote:
past wthose points it was on my dime to contract with a locate service to mark any underground lines since those are technically my responsibility.
Understood.  My question remains.
It may be as simple as saying their definition of public right of ways and yours differ.  The utility providers have easements to allow access to their lines that cross your property.  This not only includes the lines to your meters but any other line that may transit your property.  Transmission lines often do not follow roads and often bisect private property.   It’s possible In utility company jargon an easement may be referred to as public access.
The fact that transmission lines may cross your property is a good reason to call for location services before trenching even if your personal utilities are far from the excavation site.
at least around here when you call 811 they will locate lines to your meters etc.  AND they are required to also locate any lines within the easement to your property.  But they also require that before they come that you mark with flags WHERE you intend to dig.  So they will locate anything that is in the "dig" zone you outline, not necessarily mark ALL utility lines on the property.
When I installed our sprinkler system explaining what we intended to do,  they then did locate on the entire lot including easements.
