rhagfo wrote:
2oldman wrote:
stevenal wrote:
private underground pipes and cables may not be owned or maintained by member utility companies, therefore they are unable to locate them.
Unable meaning unwilling. That makes no sense. They will let a homeowner run the risk of digging up a line rather than spend 10 minutes locating it. I'll go out on a limb here and submit it's a liability issue.
Utility companies are only required to mark location of underground cables to the meter, after that it is private cabling. There are companies that will for a price come out and attempt to locate underground utilities.
At least around here 811 is a free service, likely funded by the utility companies and gov't. Purpose is to keep YOU from damaging THEIR utility and then YOU needing to pay for the damage. Saves both parties from possible damages and at a minimum expense to repair. Worst cast injury or death getting across an underground power line.
Whats on YOUR side of the utilities is YOUR repsonsibility and on YOUR dime to locate.
What is interesting in our area is that Sewer becomes your repsonsibility as soon as it hits your property line so all the sewer locate will do is mark from the manhole cover to the street.
