novasbc
Jul 09, 2018Explorer
Underperforming front A/C?
Background, I have a 2018 palomino puma unleashed toy hauler fifth wheel, with dual A/C (351THSS).
I took it in almost immediately complaining that the front a/c hardly did anything. They said they fixed it, and it was better, that there was foil blocking the vents. I felt like it still didn't do a good job, but it was getting into colder months and I really couldn't tell.
This year as it got hot, it was apparently still sub par. The lesser power unit in the garage does a much better job than the one in the front, so much so that the only way to cool it down is to put a fan in the back and blow it up to the front.
I brought it in again before the 1 year warranty was up, and they say it's performing to specifications. I have measured the air temperature coming out of the vent and yes the temperature is good, but it just seems like such low volume it can't keep up.
The other night I didn't run a fan from the back to the front, and it couldn't even get it below 80 degrees (this is Central Texas, I would think this is possible at night.
So my question, how can I either validate that it's performing to spec, or prove it needs work?
If I didn't have the garage ac I can't imagine how terrible it would be. Yes, in Texas having two seems necessary, but seems wrong never the less.
The air that comes out of the vent in the front master bedroom is barely a trickle, while in the back it's blowing like a storm.
When I checked the temperature at the vent, it was putting out 55 degree temperature, so more than 20 degrees below the outdoor temperature.
Thanks!
Mark.
Thanks!
Mark.
