donnieR32's avatar
donnieR32
Understanding Black Tank Shape
Yesterday, I cleaned my black tank by using a wand. I quickly realized what I thought was the bottom of the tank wasn't. I think my tank is shaped like a pyramid or at least is higher in the middle. The tank is 30 gallons and I could easily touch the bottom of the tank with the wand. Not to mention it still looked empty after cleaning and when I dropped a chem tab in it shot off to one side. I always thought tanks were square or at least flat bottomed with a slope towards the valve. Ideas?
  • donnieR32 wrote:
    Makes sense. I can't see mine from underneath because it is foamed and sealed. I was just curious because per usual my level sensor wasn't accurate and I wanted an idea of what to look for with a flashlight to know when it was "full".
    When you flush toilet and it 'BURPS' back at you......it's full :B
  • downtheroad wrote:
    Shape can depend on size (number of gallons.)
    Most often then are thin like about 6-8 inches deep....because they have to fit under the floor and between the frame rails...but not below the underbelly. Like the 3 on the left side of the picture below.
  • Shape can depend on size (number of gallons.)
  • Mine are shaped like that except the drain is in the middle of the long side.
  • I don't know what yours looks like, but here are a couple of examples.
    It appears that most are sloped to the drain side, which makes sense.
  • K Charles wrote:
    I think 30 gal is about 4 cubic ft. that would make a 4 ft X 8 ft tank only 6 in deep.
    Good point. Is it possible or normal for the tank to be raised in the middle?
  • I think 30 gal is about 4 cubic ft. that would make a 4 ft X 8 ft tank only 6 in deep.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
