Almot
Jan 23, 2016Explorer III
road-runner wrote:
Try this calculator http://pvwatts.nrel.gov/
At my location it is pretty much dead on after 3 years of actual data. Being meant for grid tie systems, the default inverter efficiency is set to 96%. For a battery system I'd suggest changing that to 85% to account for charge controller and battery losses.
Yes, it is accurate, I've been using it many times.
They assume 1.1 DC/AC losses or 90% inverter efficiency, not 96%.
They also assume 100% controller efficiency.
Controller efficiency is typically 95% or better (at least, in MPPT).
Hence, harvested DC energy after controller and before the battery would be 1.05 times more than in AC column. I would just leave it as is and assume DC=AC.
I would not consider battery losses here. Some old battery will have ridiculous losses, and even a new flooded battery never stops simmering and heating your space, unlike AGM that simply stops accepting charge.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
