GATJcampers's avatar
GATJcampers
Understanding solar
I am trying out solar for the first time. I have a toy hauler with 2 brand new 6 volt batteries wired in series. I got a 100 watt solar panel with a 11 amp charge controller that cuts in at 13v and cuts out at 14.2v.I hooked it up and my readings confuse me. Out of the panel I read 20.2 volts then out of the controller I read the same 20.2 volts but at the batteries I read from 12.7 - 13 volts. Don't understand why. There absolutely no load on the trailer at all, could that be why? Shouldn't the volts be between the cut-in and cut-out voltage? I boondock the majority of the time so I want to get the most out of it. Any insight or knowledge you can share would be great. Electrical is my worst topic so break it down, it won't insult me. Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
