MrWizard
Aug 31, 2017Moderator
Yep
It's working correctly
You took two measurements at different voltages
And got confused because the amps reading went up, but forgot the voltage went down
Just the reverse of an inverter, but same idea
12v * 50 amps = 600w input
120v * 5 amps = 600w output/ load , not including the conversion loss
It's important to remember that with electricity, it's about power in and power out, always compare the Watts ,(do the math)
There will always be a difference because of conversion loss
But the difference should not be too great
If there is a very large difference, then there is a problem with the conversion device
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
