Chris_Bryant
Nov 27, 2015Explorer II
You will have to replace the control box on the air, and run thermostat wires, but the Dometic single zone LCD would be what you need. It requires 3 wires between the thermostat and roof top unit- 12 volt power, ground and data. The replacement box for the roof top unit should be plug and play- if the unit has a separate control box. The kit should be around $100.
I can look up specific number tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
