B92F
Apr 09, 2017Explorer
ktmrfs wrote:
you mention the light in the fridge does NOT come on when you open the door. That indicates a problem with at least part of the 12V supply, it should come on. there are several fuses on the control board. check them and the bulb. once you get the fridge light to come on see if that fixes the problem.
The bulb and all fuses seem to be okay. Interior lights work while on battery as well. As I posted above, when I turn the climate control switch on (located above the freezer door) the check light stays on constant and does not blink.
If the bottom control board is faulty, would it prevent gas from flowing to that part of the system?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
