dougrainer
Apr 10, 2017Nomad
Chris Bryant wrote:dougrainer wrote:
I just repaired this type problem. Customer had the same type issue. IF you turned the Hi humidity switch ON, the check light stayed ON and did not flash. BAD Main control board. Replace it. Doug
Doug- which board was that? That's a new one on me.
The lower back main Module. Unit would not function on LP OR 120. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
