Chris_Bryant
Apr 10, 2017Explorer II
dougrainer wrote:Chris Bryant wrote:dougrainer wrote:
I just repaired this type problem. Customer had the same type issue. IF you turned the Hi humidity switch ON, the check light stayed ON and did not flash. BAD Main control board. Replace it. Doug
Doug- which board was that? That's a new one on me.
The lower back main Module. Unit would not function on LP OR 120. Doug
I figured that :)
Was it the original "1010", universal or integrated ignition? There is reportedly an all new Hercules board in the pipeline.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
