dougrainer
Apr 10, 2017Nomad
Chris Bryant wrote:dougrainer wrote:Chris Bryant wrote:dougrainer wrote:
I just repaired this type problem. Customer had the same type issue. IF you turned the Hi humidity switch ON, the check light stayed ON and did not flash. BAD Main control board. Replace it. Doug
Doug- which board was that? That's a new one on me.
The lower back main Module. Unit would not function on LP OR 120. Doug
I figured that :)
Was it the original "1010", universal or integrated ignition? There is reportedly an all new Hercules board in the pipeline.
Original module with the separate Ignition reignitor. I was leaning towards the eyebrow or harness from the board to the eyebrow. But, the back of the refer was very clean so animal infestation was not evident. I have never seen this malfunction before where the Hi humidity switch caused the check light to change. It was very quick and easy to install a new module and see if it worked. Which it did. This is one of those times EXPERIANCE pays off. Not all malfunctions fit the Manual or textbook repair. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
