MEXICOWANDERER
Jul 17, 2017Explorer
If testing fuel pressure does not yield the problem...
Remove DISTRIBUTOR pickup coil or put the whole damned distributor into an oven minus cap and rotor. Set oven for 250 degrees and no higher.
Bake for 30 minutes.
What is the resistance across the pickup coil wire leads? Compare the value to ohms at room temperature.
A bad pickup coil harness connector will also cause this. One hand on one side of the connector the other on the other side. Pull GENTLY. Any change?
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
